Voici les 10 derniers logiciels
déposés dans HAL UGA
  • skglm is a Python package that offers fast estimators for sparse Generalized Linear Models (GLMs) that are 100% compatible with scikit-learn. It is highly flexible and supports a wide range of GLMs. The user gets to choose from skglm's already-made estimators or customize their own by combining the tenth of available datafits and penalties.
  • Benchopt is a benchmarking suite tailored for machine learning workflows. It is built for simplicity, transparency, and reproducibility. It is implemented in Python but can run algorithms written in many programming languages.
  • Code de l'application Explore-PAB : https://explore-pab.sk8.inrae.fr/ ExplorePAB est une interface Shiny permettant d'explorer les données issues du suivi des dossiers de demande de primes Air-Bois, ainsi que les résultats de d'une analyse des données réalisée dans le cadre du stage de Gabriel Macé (2024), et ceci à travers des visualisations graphiques. Elle vise à mieux […]
  • Compilation of analytic solutions (in 1d and 2d) for free surface flow
  • SimGrid is a simulation toolkit that provides core functionalities for the simulation of distributed applications in large scale heterogeneous distributed environments.
  • ADONIS® (Acquisition of Data at INRAE) is an INRAE computer tool that meets the needs of INRAE experimenters for a modern data acquisition tool in the field. Adonis® is a functional tool, deployed at INRAE since 2013. In 2022, Adonis underwent a major evolution with the deployment of the new Adonis® WebApp and Adonis® Mobile […]
  • A `LazyLinOp` is a high-level linear operator based on an arbitrary underlying implementation, such as: – custom Python functions, – a `NumPy array`, – a `SciPy matrix`, – a `Faust` object, – any Python linear operator. Thanks to the Lazylinop API, this operator can be easily manipulated, transformed or aggregated with other linear operators to […]
  • Alumet is a modular framework for "low-level" measurement. Thanks to an extensible plugin system, the framework allows to create measure-made measurement tools for a wide range of situations, local or distributed. With a generic model and interface, it can obtain, process and export any type of measurement, in the form of multi-dimensional timeseries. In particular, […]
  • GaIn is intended to provide routines with a relatively simple interface for calculation of overlap, kinetic and 2,3 and 4 center Coulomb integrals over either Solid or Cubic Harmonics Gaussian basis sets.
  • CheSS is a library for sparse matrix manipulations.
